Problems wrapping coils
Hi all
are there any tips on how to use this with 28gauge wire? I'm trying to wrap coils put the wire keeps on rapping over itself. I'm trying to wrap a 2.5 mm coil with a set screw on the interposition but no matter what I try and up over wrapping themselves.
  • Just put a little force for the first wrap and then gentle with no force start wrapping (dont do it fast ) one by one without pressing and you'll see it is wrapping with no problem.
    Coil master its not magical you have to put some efford by yourself , just dont press it as you wrapping and you will succeed eventualy.
Sign In or Register to comment.
