Battery drain!!!
Tab 521
Used multiple types of batteries all of them after few days, with no use, are drained!!!!
Is this normal?
  • edited September 2015
    No, it is not normal for the battery to drain without using the 521.
    I have the same battery installed since I received the device and the level meter is still nearly on full - I make several coils per week on average, the rest of the time the 521 is turned off and doing nothing.
    I`ve had it for about 2 weeks now - same battery.
  • @Ivars Pepsons
    What kind of battery are you using?
Sign In or Register to comment.
